'Can't Run 16-Bit Program' Error
bonzo
I have a big problem with the software I downloaded - twice - and have reinstalled it many times just to be sure I wasn't to blame. I've just started with PICAXE (08) at school and was so excited by them I brought some home to play with.
Everything is fine - programming etc. - but when I try to download the program to the chip I get an error saying:
Can't run 16-Bit Windows program!
Cannot find file D:\....\picaxe08.exe (or one of it's components). Check to see if the file exists and filename is correct and that all the libraries are there.
Error!
Error53: File not found!
Path Error...
The following path is invalid:
D:/.../picaxe08.exe
I checked and the file is there. I use Windows XP Home. This happens with all the chips you can select. ie. D:/.../picaxe18.exe can't be found etc. If anyone can help me that would be great.
~bonzo
Edited by - bonzo on 3/1/2005 3:25:01 AM
Edited by - bonzo on 3/1/2005 3:26:23 AM
See the 'autoexec.nt' message on the software page of this website - its under the download links to the Prog Editor software.
