I have an 18X running of 4.23 Vdc - everything works fine. In production I'm going to use a 12Vdc source so I have a Reg which reliably gives me 5.041Vdc to the circuit.
so when I go to program in this second config (with the reg) it will not program, the software says the picaxe is not responding, saying voltage might be too high etc.
if I was running 6.5 or 7V I could understand.. but at 5.041 I think I should be fine still?
- http://www.hippy.freeserve.co.uk/picaxeq3.htm#what_is_the_picaxe_operating_voltage
the supply is quite clean I feel, it's from a Dick Smith Q1760 Power Supply - I would think that would have caps across the rails etc to filter - my point being that if I add a cap across the output of the Reg I'm not thinking it would do a lot. I must admit, I often don't put caps in circuits where they are shown, perhaps I'm underestimating the value of the filtering from Caps and this is a practical ramification?
