Hi
I have built a circuit on prototype board using a PICAXE 14M coupled to 2: 4511's using the data lines as per diagram in the manual, the 4511's are connected to the data lines in parallel. I then use outputs 4 and 5 of the PICAXE for the LE pins on the 4511's. In my program I use the "let pins = b1" comand to send data to the 4511's. I try to make outputs 4 and 5 control the tens and units seven segment displays. The circuit works at counting from 0 to 9 but because the "letpins" command controls the whole port I have no control over outputs 4 and 5. Apart from writing subroutines for each digit I can't seem to come up with a simple solution. My question is, is there a simpler way??
Thanks
Tony
Thanks
Tony
