I know you can use serout to control pins on a slaved picaxe, connected by an output pin on the master, to a input pin of the slaved picaxe.
If I had say have a master 18x that I wanted to control a 08m as the slave. In this instance I dont simply want to control pins on the 08m, i want to use the 08m's pwmout feature and vary duty cycle etc by commands sent from the 18x. Basically I want to use the 08m as a slave PWM handler to run a seperate circuit and it needs high frequency switching and constantly adjustable duty cycle
Is this possible?
Any help would be appreciated!
Adrian
Is this possible?
Adrian
