Yes, thats exactly what I meant, I found on ebay a USB to 3.5mm jack cable. I have previously used USB - serial converters when we were using serial cables on old pcs. I read on the official picaxe web site that they prefer the use of the USB cable because it says the following "This USB cable is a 5V logic level device, so works far better than a 'serial cable + universal USB-RS232 adapter' combination when, for instance, calibrating touch sensors with the PICAXE software". I want the cable for general programming of vehicles and will not use add on sensors for projects. So would you consider the serial with a USB converter a viable option? Thank you
