I thought there was a row of holes between the PICAXE chip and the UL2803A Darlington Array which could have header pins fitted or soldered to but I may be wrong.I'd like to use porB to control 4 motors with external dirvers. But I think I have not direct conecctios to PICAXE B pins (Axe020).
No, you can use any motor driver which suits your needs.It is necesary to use a L923D driver?
The data sheet for AXE020 Version 3.0 04/2010 suggests that the more recent revision of the PCB does have provision for an in-line header between 28-pin socket and the ULN2803A. However, I wouldn't bet my life on it!I thought there was a row of holes between the PICAXE chip and the UL2803A Darlington Array which could have header pins fitted or soldered to but I may be wrong.
