ooooh! Now that I didn't know! I just assumed from previous experience that pre-processor and compiler directives shouldn't be mixed... even more optimization possible then....If you have
(for example),Code:#DEFINE number 21
then you can write
Code:SYMBOL LoopCount = number - 1 for i = 1 to LoopCount
With the new knowledge from Aries as above, that definitely makes more senseWhy is your set of "#IF"s better than this?
loopend=number min 1 max 26-1 ' limit 0-25
for i=0 to loopend
I have to agree. It's probably just lack of advanced programming experience which is holding danners430 back from that.Much of the code is repetitive, varying only variables and pin numbers. You could probably combine multiple instances of similar code into a single instance in a loop
#Picaxe 20X2
#No_Data
Symbol I2C_DEVICE_ADDRESS = %01010010 ; $A2
#Define NUMBER 11
; Sensor input pin definitions
Table 1, ( B.0 )
Table 2, ( B.1 )
Table 3, ( B.2 )
Table 4, ( B.3 )
Table 5, ( B.4 )
Table 6, ( B.5 )
Table 7, ( B.6 )
Table 8, ( C.7 )
Table 9, ( C.3 )
Table 10, ( C.2 )
Table 11, ( C.1 )
; Addresses used in Scratchpad
; I2cRead $00, (b0) Status of LDR #1
; I2cRead $01, (b0) Status of LDR #2
; etc
; I2cRead $18, (b1,b0) Dark bits, bit0 = LDR#1
; I2cRead $20, (b0) Raw ADC of LDR #1
; I2cRead $30, (b0) Average of LDR #1
Symbol ADR_STATUS = $00 ; $00-$17 24 bytes
Symbol ADR_DARK_BITS = $18 ; $18-$19 1 word
Symbol ADR_RAW = $20 ; $20-$2A 11 bytes
Symbol ADR_AVERAGE = $30 ; $30-$3A 11 bytes
Symbol ADR_TOTAL = $40 ; $40-$5B 11 words
; Scratchpad access macros
#Define ReadByte(n,adr,var) ptr = n - 1 + adr : var = @ptr
#Define SaveByte(n,adr,var) ptr = n - 1 + adr : @ptr = var
#Define ReadWord(n,adr,varMsb,varLsb) ptr = n - 1 * 2 + adr : varLsb = @ptrInc : varMsb = @ptr
#Define SaveWord(n,adr,varMsb,varLsb) ptr = n - 1 * 2 + adr : @ptrInc = varLsb : @ptr = varMsb
; Variables used
Symbol reserveW0 = w0 ; b1:b0
Symbol darkBits = w1 ; b3:b2
Symbol darkBits.lsb = b2
Symbol darkBits.msb = b3
Symbol samples = w2 ; b5:b4
Symbol total = w3 ; b7:b6
Symbol total.lsb = b6
Symbol total.msb = b7
Symbol n = b8
Symbol pinNumber = b9
Symbol adc = b10
Symbol average = b11
Symbol darkLevel = b12
Symbol bitMask = b13
Symbol status = b14
; Program code
PowerOnReset:
Hi2cSetup I2CSLAVE, I2C_DEVICE_ADDRESS
MainLoop:
samples = samples + 1 Max 256
For n = 1 To NUMBER
ReadTable n, pinNumber
ReadAdc pinNumber, adc
SaveByte( n, ADR_RAW, adc )
Gosub UpdateAverage
Gosub UpdateStatus
Next
UpdateAverage:
ReadWord( n, ADR_TOTAL, total.msb, total.lsb )
ReadByte( n, ADR_AVERAGE, average )
If samples = 256 Then
total = total - average + adc
average = total.msb
Else
total = total + adc
average = total / samples
SaveWord( n, ADR_TOTAL, total.msb, total.lsb )
SaveByte( n, ADR_AVERAGE, average )
UpdateStatus:
darkLevel = 80 * average / 100
bitMask = 1 << n >> 1
If average < darklevel Then
darkBits = darkBits | bitMask ; Set Bit
status = %01000011 ; Occupied
Else
darkBits = darkBits &/ bitMask ; Clear Bit
status = %01000010 ; Clear
SaveWord( 1, ADR_DARK_BITS, darkBits.msb, darkBits.lsb )
SaveByte( n, ADR_STATUS, status )
Now +there+ is a masterclass lesson--#define constants, #define macros, TABLE definitions, scratchpad usage, indirection with @ptr, meaningful symbolic names, array handling, and more.it could be compacted to something fairly simple without losing understandability.
Good catch. As someone (probably hippy) pointed out to me years ago, you can use, for instance, READADC B.1,result in your program because the preprocessor recognizes your intention and puts the right code in. However, if you use B5=B.1: READADC B5,result, the preprocessor can't read your mind to understand that B5 holds the standard pin number rather than the ADC pin number. So you must use the ADC pin number when using a variable.Also, just to clear up my confusion... I thought readADC had to use the ADC number given on the datasheet instead of the pin number in port.pin format? Or can it use either or?
Theoretically, the simple fix would be to replace the pin numbers with the ADC numbers in the Table at the beginning of the program - and for clarity comment the pin number beside it. Mind you, it does compile and simulate on PE6...Good catch. As someone (probably hippy) pointed out to me years ago, you can use, for instance, READADC B.1,result in your program because the preprocessor recognizes your intention and puts the right code in. However, if you use B5=B.1: READADC B5,result, the preprocessor can't read your mind to understand that B5 holds the standard pin number rather than the ADC pin number. So you must use the ADC pin number when using a variable.
(If I have misunderstood this, or mis-applied it, someone please correct me. (And is there a programmatic way to get "ADC pin number of B.1"?))
Yes, the #DEFINE can be rewritten as multi-line #MACRO blocks, without any effect on the functionality.I'm assuming that the four #DEFINE statements in lines 39-42 could easily be re-written as a multi-line macro for readability (just by splitting the statements separated by colons into separate lines and changing the directives to #MACRO / #ENDMACRO)?
You can use either directly with the READADC commands, but only when used directly. If a number is loaded into a variable which is used in a READADC command that must be the channel number. For example, on the 20X2 ...Also, just to clear up my confusion... I thought readADC had to use the ADC number given on the datasheet instead of the pin number in port.pin format? Or can it use either or?
b0 = B.3
ReadAdc b0, b1 ; Reads ADC3, which is on leg C.7
; .---------------- Light sensor number
; | .---------- ADC channel number
; | | .--- ADC pin name
Table 1, ( 1 ) ; B.0
Table 2, ( 2 ) ; B.1
Table 3, ( 4 ) ; B.2
Table 4, ( 5 ) ; B.3
Table 5, ( 8 ) ; B.4
Table 6, ( 10 ) ; B.5
Table 7, ( 11 ) ; B.6
Table 8, ( 3 ) ; C.7
Table 9, ( 7 ) ; C.3
Table 10, ( 8 ) ; C.2
Table 11, ( 9 ) ; C.1
Yet it compiles and simulates correctly without change... Methinks this bug might be a butterfly...So I guess that is a bug in my code through oversight; the pin names used in the DATA definitions should be ADC channel numbers rather than pin names.
I find that when stepping through in simulation with a 20X2, on the first READADC it totally locks up PE6, requiring it to be terminated with Task Manager. Presumably, this is because the first adc command, which is effectively READADC 0,adc, is trying to read a non-existent ADC pin, ADC0.Yet it compiles and simulates correctly without change
I believe (as modified with the new table values), it would run as expected--but I also don't have a convenient way to get 11 distinct ADC values (though I wonder what you would get if the pins are just floating).so... I wonder what happens if you load it onto a chip...? Unfortunately I can't test it just now...
Aye, with the updated table values it runs perfectly fine in the simulator too... Just (morbidly) curious to see what the "old" code would do!I believe (as modified with the new table values), it would run as expected--but I also don't have a convenient way to get 11 distinct ADC values (though I wonder what you would get if the pins are just floating).
As it turns out, the "old" code +will+ work on a 20M2 (as far as the READADCs go) because on the M2 parts, the pin number is the same as the ADC pin number. But everything using PTR won't work, because scratchpad is not available on the M2s--however the code could be rewritten to use bptr and upper RAM.Just (morbidly) curious to see what the "old" code would do!
' 20masterclass ' hippy's from https://picaxeforum.co.uk/threads/calibrating-ldr-using-a-separate-ambient-ldr.31720
'#Picaxe 20X2
#Picaxe 20M2
#terminal 4800
#No_Data
'#define px20X2
#Define NUMBER 11
#ifdef px20X2
Table 5, ( 6 ) ; B.4
#else
Table 1, ( B.0 )
Table 2, ( B.1 )
Table 3, ( B.2 )
Table 4, ( B.3 )
Table 5, ( B.4 )
Table 6, ( B.5 )
Table 7, ( B.6 )
Table 8, ( C.7 )
Table 9, ( C.3 )
Table 10, ( C.2 )
Table 11, ( C.1 )
#endif
; etc
; Variables used
Symbol n = b8
Symbol adc = b10
Symbol status = b14
; Program code
PowerOnReset:
#ifdef px20X2
#endif
MainLoop:
For n = 1 To NUMBER
sertxd(#pinNumber,"-",#adc," ")
#ifdef px20X2
#endif
Gosub UpdateAverage
Gosub UpdateStatus
Next
sertxd(cr,lf)
UpdateAverage:
#ifdef px20X2
average = total.msb
Else
total = total + adc
#endif
UpdateStatus:
#ifdef px20X2
Else
#endif
0-59 1-36 2-0 3-31 4-0 5-8 6-0 15-0 11-0 10-28 9-4
0-0 1-17 2-12 3-0 4-16 5-0 6-18 15-0 11-25 10-4 9-0
0-0 1-2 2-19 3-15 4-0 5-5 6-9 15-0 11-0 10-18 9-1
0-0 1-32 2-6 3-29 4-5 5-2 6-0 15-0 11-0 10-0 9-5
0-0 1-6 2-3 3-33 4-3 5-1 6-0 15-0 11-0 10-0 9-6
0-0 1-30 2-17 3-0 4-18 5-0 6-22 15-0 11-30 10-7 9-0
0-0 1-54 2-26 3-5 4-0 5-5 6-4 15-0 11-4 10-11 9-0
0-0 1-54 2-15 3-43 4-92 5-0 6-3 15-0 11-0 10-0 9-2
0-97 1-55 2-61 3-55 4-0 5-3 6-0 15-0 11-0 10-0 9-0
0-0 1-33 2-7 3-54 4-3 5-7 6-0 15-0 11-0 10-0 9-0
0-0 1-54 2-17 3-20 4-43 5-0 6-58 15-6 11-0 10-0 9-0
0-48 1-49 2-0 3-46 4-0 5-2 6-0 15-0 11-0 10-0 9-0
0-0 1-8 2-0 3-7 4-2 5-3 6-37 15-0 11-0 10-0 9-0
0-0 1-53 2-25 3-25 4-10 5-0 6-13 15-0 11-14 10-1 9-0
0-0 1-54 2-27 3-18 4-0 5-4 6-1 15-0 11-0 10-0 9-0
0-0 1-54 2-26 3-6 4-0 5-7 6-0 15-0 11-0 10-22 9-4
0-0 1-54 2-25 3-3 4-23 5-0 6-37 15-0 11-0 10-0 9-0
0-0 1-54 2-27 3-4 4-8 5-1 6-38 15-0 11-0 10-0 9-0
0-0 1-53 2-25 3-4 4-0 5-8 6-0 15-0 11-0 10-0 9-0
0-0 1-60 2-32 3-7 4-0 5-1 6-6 15-6 11-5 10-46 9-6
Me too. I guess a bug report needs filing.I find that when stepping through in simulation with a 20X2, on the first READADC it totally locks up PE6, requiring it to be terminated with Task Manager.
#ifdef px20X2
#Picaxe 20M2
#IfDef _20M2
SerTxd( "20M2 ")
#EndIf
#IfDef _20X2
SerTxd( "20X2 ")
#EndIf
#IfNDef _20M2
SerTxd( "- Not 20M2", Cr, LF )
#EndIf
#IfNDef _20X2
SerTxd( "- Not 20X2", CR, LF)
#EndIf
Thanks for that.PE6 already includes automatic handling of conditional code for whichever PICAXE type is selected. Just specify the type with an underline in front.
'#Picaxe 20X2
#Picaxe 20M2
#terminal 4800
#No_Data
#Define NUMBER 11
#ifdef _20X2
#else
Table 1, ( B.0 )
Table 2, ( B.1 )
Table 3, ( B.2 )
Table 4, ( B.3 )
Table 5, ( B.4 )
Table 6, ( B.5 )
Table 7, ( B.6 )
Table 8, ( C.7 )
Table 9, ( C.3 )
Table 10, ( C.2 )
Table 11, ( C.1 )
#endif
; etc
Symbol ADR_STATUS = $100 ; $100-$117 24 bytes
Symbol ADR_DARK_BITS = $118 ; $118-$119 1 word
Symbol ADR_RAW = $120 ; $120-$12A 11 bytes
Symbol ADR_AVERAGE = $130 ; $130-$13A 11 bytes
Symbol ADR_TOTAL = $140 ; $140-$15B 11 words
#ifdef _20X2
#else
#Define ReadByte(n,adr,var) bptr = n - 1 + adr : var = @bptr
#Define SaveByte(n,adr,var) bptr = n - 1 + adr : @bptr = var
#Define ReadWord(n,adr,varMsb,varLsb) bptr = n - 1 * 2 + adr : varLsb = @bptrInc : varMsb = @bptr
#Define SaveWord(n,adr,varMsb,varLsb) bptr = n - 1 * 2 + adr : @bptrInc = varLsb : @bptr = varMsb
#endif
; Variables used
Symbol n = b8
Symbol adc = b10
Symbol status = b14
Symbol loopCnt = b15
; Program code
PowerOnReset:
#ifdef _20X2
#endif
MainLoop:
For n = 1 To NUMBER
sertxd(#n,"@",#pinNumber,"-",#adc," ")
Gosub UpdateAverage
Gosub UpdateStatus
Next
sertxd(cr,lf)
loopCnt = loopCnt + 1
if loopCnt = 32 then
loopCnt = 0
sertxd("AVERAGES: ")
for n = 1 to NUMBER
sertxd(#n,"-",#average," ")
next n
sertxd(cr,lf)
UpdateAverage:
average = total.msb
Else
total = total + adc
UpdateStatus:
' bitMask = 1 << n >> 1
lookup n,(0,1,2,4,8,16,32,64,128,256,512,1024),bitmask
Else
1@0-55 2@1-54 3@2-22 4@3-21 5@4-70 6@5-0 7@6-0 8@15-0 9@11-69 10@10-53 11@9-7
1@0-1 2@1-18 3@2-11 4@3-20 5@4-12 6@5-0 7@6-33 8@15-0 9@11-2 10@10-5 11@9-3
1@0-7 2@1-3 3@2-0 4@3-0 5@4-17 6@5-1 7@6-4 8@15-0 9@11-0 10@10-28 11@9-15
1@0-1 2@1-12 3@2-4 4@3-0 5@4-0 6@5-5 7@6-1 8@15-0 9@11-0 10@10-0 11@9-1
1@0-0 2@1-8 3@2-0 4@3-0 5@4-0 6@5-6 7@6-0 8@15-18 9@11-78 10@10-13 11@9-0
1@0-0 2@1-2 3@2-36 4@3-0 5@4-0 6@5-0 7@6-0 8@15-0 9@11-0 10@10-3 11@9-2
1@0-0 2@1-0 3@2-0 4@3-0 5@4-9 6@5-0 7@6-0 8@15-0 9@11-0 10@10-0 11@9-0
1@0-20 2@1-13 3@2-2 4@3-0 5@4-0 6@5-0 7@6-0 8@15-0 9@11-0 10@10-1 11@9-1
1@0-67 2@1-49 3@2-19 4@3-3 5@4-0 6@5-9 7@6-2 8@15-0 9@11-0 10@10-0 11@9-0
1@0-11 2@1-13 3@2-1 4@3-0 5@4-0 6@5-0 7@6-0 8@15-6 9@11-18 10@10-12 11@9-3
1@0-1 2@1-30 3@2-173 4@3-180 5@4-184 6@5-1 7@6-178 8@15-42 9@11-32 10@10-115 11@9-8
1@0-24 2@1-40 3@2-73 4@3-98 5@4-71 6@5-11 7@6-4 8@15-0 9@11-41 10@10-26 11@9-5
1@0-123 2@1-119 3@2-73 4@3-71 5@4-123 6@5-7 7@6-139 8@15-31 9@11-1 10@10-95 11@9-8
1@0-25 2@1-22 3@2-6 4@3-11 5@4-8 6@5-6 7@6-36 8@15-0 9@11-105 10@10-87 11@9-2
1@0-0 2@1-33 3@2-2 4@3-23 5@4-40 6@5-0 7@6-59 8@15-3 9@11-0 10@10-35 11@9-15
1@0-14 2@1-48 3@2-53 4@3-57 5@4-43 6@5-6 7@6-0 8@15-0 9@11-5 10@10-46 11@9-15
1@0-78 2@1-119 3@2-158 4@3-23 5@4-27 6@5-0 7@6-0 8@15-0 9@11-0 10@10-42 11@9-5
1@0-62 2@1-108 3@2-83 4@3-39 5@4-18 6@5-6 7@6-0 8@15-0 9@11-43 10@10-72 11@9-7
1@0-0 2@1-19 3@2-0 4@3-14 5@4-13 6@5-0 7@6-0 8@15-0 9@11-107 10@10-106 11@9-8
1@0-85 2@1-85 3@2-44 4@3-9 5@4-0 6@5-0 7@6-22 8@15-0 9@11-100 10@10-109 11@9-9
1@0-49 2@1-50 3@2-29 4@3-0 5@4-55 6@5-4 7@6-32 8@15-0 9@11-0 10@10-1 11@9-8
1@0-0 2@1-0 3@2-0 4@3-0 5@4-0 6@5-14 7@6-28 8@15-0 9@11-0 10@10-25 11@9-0
1@0-0 2@1-19 3@2-55 4@3-47 5@4-85 6@5-9 7@6-2 8@15-0 9@11-24 10@10-17 11@9-5
1@0-1 2@1-49 3@2-8 4@3-65 5@4-41 6@5-0 7@6-67 8@15-6 9@11-1 10@10-31 11@9-13
1@0-3 2@1-15 3@2-0 4@3-0 5@4-0 6@5-10 7@6-0 8@15-0 9@11-0 10@10-0 11@9-0
1@0-0 2@1-12 3@2-0 4@3-58 5@4-27 6@5-0 7@6-0 8@15-0 9@11-0 10@10-0 11@9-0
1@0-19 2@1-31 3@2-8 4@3-2 5@4-0 6@5-0 7@6-55 8@15-0 9@11-0 10@10-7 11@9-2
1@0-10 2@1-35 3@2-21 4@3-42 5@4-15 6@5-0 7@6-0 8@15-0 9@11-4 10@10-3 11@9-0
1@0-0 2@1-34 3@2-8 4@3-0 5@4-0 6@5-2 7@6-33 8@15-0 9@11-0 10@10-76 11@9-4
1@0-2 2@1-40 3@2-9 4@3-0 5@4-0 6@5-2 7@6-22 8@15-0 9@11-0 10@10-0 11@9-1
1@0-6 2@1-47 3@2-10 4@3-0 5@4-0 6@5-0 7@6-0 8@15-0 9@11-0 10@10-0 11@9-0
1@0-0 2@1-55 3@2-16 4@3-2 5@4-0 6@5-0 7@6-2 8@15-0 9@11-0 10@10-134 11@9-4
AVERAGES: 1-20 2-36 3-28 4-24 5-26 6-3 7-22 8-3 9-19 10-35 11-4
#IfDef _20X2
Symbol ADR_BASE = $00
#Else
Symbol ptr = bPtr
Symbol @ptr = @bPtr
Symbol @ptrInc = @bPtrInc
Symbol @ptrDec = @bPtrDec
Symbol ADR_BASE = $10
#EndIf
Symbol ADR_STATUS = ADR_BASE + $00 ; $00-$17 24 bytes
Symbol ADR_DARK_BITS = ADR_BASE + $18 ; $18-$19 1 word
Symbol ADR_RAW = ADR_BASE + $20 ; $20-$2A 11 bytes
Symbol ADR_AVERAGE = ADR_BASE + $30 ; $30-$3A 11 bytes
Symbol ADR_TOTAL = ADR_BASE + $40 ; $40-$5B 11 words
That looks right and it revealed another bug in my code. I have 'bitMask' defined as a byte variable where it should be a word variable.Otherwise, only one significant statement was changed, "bitMask = 1 << n >> 1" to "lookup n,(0,1,2,4,8,16,32,64,128,256,512,1024),bitmask". I hope I didn't break anything.
Only because ofBut I'm not sure why we're embarking on the 20M2 adventure seeing as it can't be used as an I2C Slave.
and I didn't have a 20X2 handy. As a bonus, that made me realize that for the M2s, the B.1, etc. pin numbers were the same as the ADC pin numbers.so... I wonder what happens if you load it onto a chip...? Unfortunately I can't test it just now...
It only needs to be set so it's above the last variable used.Doesn't ADR_BASE for the M2 need to be higher, like $30?
No, I believe the PIC(axe) always performs a 10 bit conversion (into two bytes), which can be configured as either "Left Justified" or "Right Justified" within a 16-bit word. For an 8-bit result it is Left-Justified and the High byte is used, whilst for 10 bits it is Right-Justified and both bytes used. Since the READADC command takes around 800 PIC Instruction Cycles (the fastest PICaxe commmands take around 400) , then a "an additional clock cycle or two" won't make much difference anyway.I'm guessing the 8-bit ADC command does two left-shifts to turn the 10-bit value into an 8-bit value... this presumably uses an additional clock cycle or two...?
It might depend exactly how it's done, but I'd guess around 1/4 .Just trying to work out what the time difference would be between taking 64 10-bit samples and taking 256 8-bit samples!
That makes sense - I'll stick to 8-bit values... at the end of the day, it's not like I need ridiculously accurate readings!It effectively takes the same time to read 10-bit ADC as it does 8-bit, probably just a few microseconds difference at 4MHz. Adding extra PICAXE commands will add delays which are a magnitude or two greater.
And there's nothing here which is that time dependent. Neither size of ADC readings nor number of samples would greatly affect things.
On the other hand, there doesn't seem to be any actual gain in using 10-bit ADC samples. It just adds complication and requires more data memory. Plus it takes a lot more time to read and write words rather than bytes. You won't create any useful better average nor make it easier to determine a detection.
I can only see disadvantages and wasted time in doing it, no advantages.
