Here is a Calender/Clock/Temperature display using the PICAXE 18M2 with the DS3231 based Chronodot. It does not have any provision to adjust the DS3231 because once you have programmed the correct data into it, it will keep track of the passage of time as long as the battery backup is connected.
The program has therefore two versions, one has a way of initially programming the DS3231, while the other does not, and is used to run the clock on a day by day basis. The selection is made by commenting out the statement that will prohibit the programming of the DS3231. (Line 79 of the program).
This means that you have to load the program twice, first to allow the Chronodot to be programmed, then the second time to run the program with the now programmed Chronodot. Hopefully you should not have to reset it untill your battery goes out. (abt 8 years)
The program is using parts of previously written snippets by other authors. Any comments are wellcome!
#rem
Display on a 16x2 LCD display the weekday, month, date,and year on 1st line
and time and temperature on the 2nd line using the Sparkfun LCD serial Adaptor.
Use the Chronodot DS3231 module as a time keeping device.
LCD display:
1st line | THU,SEP 19 2013 |
2nd Line | 11:46:23 A 78.5 |
(Re-arrange to display Date and 24H clock according to European Standards).
PICAXE 18M2 Port assignments:
Program Serial OUT = C.3 -- Use standard circuit
Program Serial IN = C.4 -- for this
I2C SCL = B.3 -- connect to SCL Pin of Chronodot-Use 4K7 pull up resistor
I2C SDA = B.4 -- connect to SCA Pin of Chronodot-Use 4K7 pull up resistor
Serial LCD output = B.7
#endrem
SYMBOL LCD = B.7 'LCD serial output
SYMBOL chr1 = B2
SYMBOL chr2 = B3
SYMBOL chr3 = B4
SYMBOL chr4 = B5
SYMBOL chr5 = B6
SYMBOL chr6 = B7
SYMBOL hrs = B10
SYMBOL mins = B11
SYMBOL secs = B12
SYMBOL wkday = B13
SYMBOL date = B14
SYMBOL month = B15
SYMBOL year = B16
SYMBOL ampm = B17
'Used only in Temp Display
SYMBOL temp = W4 'b9-b8
SYMBOL TempMsb = B9
SYMBOL TempLsb = B8
#picaxe 18M2
#no_data
setfreq M16
HI2Csetup I2Cmaster, %11010000, I2Cfast_16, I2Cbyte
clr: 'Clear LCD Window Subroutine
serout LCD,T9600_16,($FE,$01)
pause 500 'needs some time to process
'Comment the following statement out if you want to set the clock.
goto version
'Set the Chronodot here
let secs = 0
let mins = $39
let hrs = $62 '41-52 =AM, 61-72 =PM (1-12) Use $0-$24 for 24HR clock and change AM/PM reading
let date = $18
let wkday = 4
let month = 9
let year = $13
'prog time (secs,mins,hours,day,date,month,year) ' hours AM 1-12 ($41 to $52)
' hours PM 1-12 ($61 to $72)
Program:
HI2Csetup I2Cmaster, %11010000, I2Cfast_16, I2Cbyte ' set to 100kbps
HI2Cout $0,( secs,mins ,hrs,wkday,date,month,year) ' write time to DS3231 example (11.58.00 PM)
HI2Cout 14, ($40) ' control (turn off 1hz, =$0 )Pin3( and off $4)
version:
serout LCD,T9600_16,($FE,$80," 18M2 Chronodot ")
pause 400
serout LCD,T9600_16,($FE,$C0," VERSION 1.0 ")
pause 15000
'Start with getting the Calender Data and Displaying it
HI2Cin $3,(wkday,date,month,year)
'WEEKDAY
SELECT CASE wkday
'cursor position12 line1
' ($FE,$80,"0123456789ABCDEF")
case $1 :serout LCD,T9600_16,($FE,$80,"SUN,")
case $2 :serout LCD,T9600_16,($FE,$80,"MON,")
case $3 :serout LCD,T9600_16,($FE,$80,"TUE,")
case $4 :serout LCD,T9600_16,($FE,$80,"WED,")
case $5 :serout LCD,T9600_16,($FE,$80,"THU,")
case $6 :serout LCD,T9600_16,($FE,$80,"FRI,")
case $7 :serout LCD,T9600_16,($FE,$80,"SAT,")
ENDSELECT
'MONTH
SELECT CASE month:
' ($FE,$84,"456789ABCDEF")
case $1 :serout LCD,T9600_16,($FE,$84,"JAN ")
case $2 :serout LCD,T9600_16,($FE,$84,"FEB ")
case $3 :serout LCD,T9600_16,($FE,$84,"MAR ")
case $4 :serout LCD,T9600_16,($FE,$84,"APR ")
case $5 :serout LCD,T9600_16,($FE,$84,"MAY ")
case $6 :serout LCD,T9600_16,($FE,$84,"JUN ")
case $7 :serout LCD,T9600_16,($FE,$84,"JUL ")
case $8 :serout LCD,T9600_16,($FE,$84,"AUG ")
case $9 :serout LCD,T9600_16,($FE,$84,"SEP ")
case $A :serout LCD,T9600_16,($FE,$84,"OCT ")
case $B :serout LCD,T9600_16,($FE,$84,"NOV ")
case $C :serout LCD,T9600_16,($FE,$84,"DEC ")
ENDSELECT
'CALENDER
BCDTOASCII date,chr1,chr2
BCDTOASCII year,chr3,chr4
'Suppress leading zero of Date
if chr1 = "0" then goto disply_date
goto disply_date1
disply_date:
serout LCD,T9600_16,(" ",chr2,",","20",chr3,chr4) 'Like "TUE,SEP 9,2013" on first line
'No leading zero here
disply_date1:
serout LCD,T9600_16,(chr1,chr2," ","20",chr3,chr4) 'Like "TUE,SEP 29,2013" on first line
'Now get the Time and display it
HI2Cin $0,(secs,mins,hrs)
ClockDisplay:
LET hrs = hrs - $40 :ampm = "A" ' 12 hour format AM
IF hrs > $20 THEN : LET hrs = hrs - $20 : ampm ="P": ENDIF ' 12 hour format PM
BcdTOASCII hrs,chr1,chr2 : IF chr1 = "0" THEN : chr1 = " " : ENDIF ' zero blanking chr1
BcdTOASCII mins ,chr3,chr4
BcdTOASCII secs ,chr5,chr6
'Now display the Time on 2nd Line
serout LCD,T9600_16,($FE,$C0)
serout LCD,T9600_16,(chr1,chr2,":",chr3,chr4,":",chr5,chr6," ",ampm," ") '(12:00:01 A)
'Now the get the Temperature
HI2Cin $11,(TempMsb,TempLsb)
Convert: temp = temp +14080 **46080 -6700
LET chr1 = " " ' chr1 (Sign) Display +
IF TempMsb > 127 THEN : temp = - temp : LET chr1 = "-" : ENDIF ' chr1 (Sign) Display "-"
'Now display the temperature in Fahrenheit
'(We do not display the Temp in the .01 ( 1/100th - chr5) place (No Room)
Display: BinTOASCII temp,chr1,chr2,chr3,chr4,chr5 ' 101.25
IF chr1 = "0" THEN : chr1 = " " ' zero blanking
IF chr2 = "0" THEN : chr2 = " " : ENDIF ' zero blanking
ENDIF
serout LCD,T9600_16,(chr1,chr2,chr3,".",chr4) '101.6 or -10.4 (F)
end
