There have been a number of requests on the PICAXE forum for a routine to calculate logarithms using PICAXE math functions.
While there is the MicroMega uM-FPU chips which come at an extra cost but can perform these functions relatively quickly and easily
if one is only after a log function, then a PICAXE based routine may suffice.
The below code will accept an integer number from 1 to 65535 and calculate the Log to base 10.
For this code, I have gone back to first principles and used the information from the book:
The Art of Computer Programming Volume 1 - by Donald E. Knuth
The concept is extremely easy and the major hurdle is handling very large numbers often far greater than 65536.
In fact numbers up to around 100 Million are involved in an attempt to maintain accuracy.
That said, the accuracy I have observed by entering quite a few numbers and comparison with MS Excel
indicates that results are usually within ~0.0002, but occasionally may be out by ~0.002.
Note that from Log10, values to base 2 or natural logs, if required, can be calculated using a fixed scaling factor.
The number of BASIC variables in the above routine can be reduced by carefully reworking the code, but presented here, so folks may better understand how it works.
; Calculate logarithms (base 10) for an integer value from 1 to 65535
; The routine is based on the text in Chapter 1.2.2 in the book
; The Art of Computer Programming by Donald E. Knuth
; Log10(x) = n + b1/2 + b2/4 + b3/8 + b4/16 . . . + b16/65536
; Picaxe routine created from the above formula by
; Westaust55 (Perth, Western Australia)
; Accuracy by observation comaped with MS Excel is that results
; are within 0.0002 but occasionally may be out by ~0.002
; Date: 28 Oct 2011
; Rev: 0
#PICAXE 40X1
#NO_DATA
#NO_TABLE
; define variable alias names
SYMBOL Reserved = b0 ; reserved for bit values
SYMBOL LogMbit = bit0
SYMBOL x = w4 ; w4 = b9:b8
SYMBOL MantSrc = w5 ; w5 = b11:b10
SYMBOL HiMword = w6 ; w6 = b13:b12
SYMBOL LoMWord = w7 ; w7 = b15:b14
SYMBOL LogMant = w8 ; w8 = b17:b16
SYMBOL Part1a = w9 ; w9 = b19:b18
SYMBOL Part1b = w10 ; w10 = b21:b20
SYMBOL Part2 = w11 ; w11 = b23:b22
SYMBOL Charact = b26
SYMBOL Counter = b27
; start of the program example
Main:
; Entry of a value
DataEntry:
SERTXD ( "Input an value:")
SERRXD [65000], #x ; early 40X1 parts Must have the timeout - PE tells you so!
SERTXD (cr,lf,"Entered Value: ", #x, cr,lf)
; Calculate the Integer Part (aka Characteristic) of the logarithm
MantSrc = x ; original value forms the source for the mantissa
Charact = 0 ; clear the Characteristic/Integer part in case second call
DO WHILE MantSrc >= 10 ; for each decade
INC Charact ; increment the Characterstic
MantSrc = MantSrc / 10 ; reduce the input value by one decade
LOOP
; Calculate Fractional part (aka Mantissa) of the logarithm
; here we scale the value by 1000 to have an integer value of reasonable size to work with
IF x > 9999 THEN
MantSrc = x / 10
ELSEIF x > 999 THEN
MantSrc = x * 1
ELSEIF x >99 THEN
MantSrc = x * 10
ELSEIF x > 9 THEN
MantSrc = x * 100
ELSE
MantSrc = x * 1000
ENDIF
LogMant = 0 ; clear the Log10 mantissa in case second routine call
; determine "bx" for each of b1 to b16
FOR Counter = 1 to 16 ; for each bit for a full word value
HiMword = MantSrc ** MantSrc
Part1a = HiMword * 6 ; divide 1000 and multiply by 65536 over next 3 lines
Part1b = HiMword * 5
Part2 = HiMword * 53 /100 ; in reality this is mult by 65.536 to 2 decimal places
LoMWord = HiMword * 6 / 1000
; HiMword =
LoMWord = MantSrc * MantSrc / 1000 ; calc low word and divide low word by 1000
; determine each "bx" bit for the log mantissa
LogMbit = 0 ; clear the "bx" bit by default - then set below as required
IF Part1A > 999 THEN ; overflow would occur so in effect divide by 10 here
MantSrc = Part1b + Part2 + LoMWord / 10 + Part1a + 2
LogMbit = 1
ELSE
MantSrc = Part1a * 10 + Part1b + Part2 + LoMWord + 2 ; calc new Mantissa value - add 2 for integer rounding error
IF MantSrc >= 10000 THEN ; if over 10,000 then reduce by a decade and set log "bx" bit
MantSrc = MantSrc/10
LogMbit = 1
ENDIF
ENDIF
LogMant = LogMant * 2 + LogMbit ; shift left one bit and include the latest "bx" bit
NEXT Counter ; contine until 16 bits are calculated
; For the mantissa we now have a value where bit15 = 0.50, bit14 = 0.250, bit13 = 0.125, etc
; Move the value 4 decimal places to the left to create an integer value that we can understand
; so for example, 0.3010 appears as %0101100101110111 (=dec 119) but after "shift" will become 3010
LogMant = LogMant ** 10000 ;
; now print out the result for Log10(x) for the entered value for x
SERTXD ("Log(",#x,") = ",#Charact,".")
IF LogMant <10 THEN
SERTXD ("000")
ELSEIF LogMant <100 THEN
SERTXD ("00")
ELSEIF LogMant <1000 THEN
SERTXD ("0")
ENDIF
SERTXD (#LogMant, cr,lf,cr,lf)
GOTO Main
