Hello,
I have done a thread search and found nothing with regards to C#. Although C# is a bit short for the search so my apologies if I am recovering old ground.
I have tried few languages to try and "talk" to my picaxe(s) (other than hyperterm) and it's early days but C# is probably the friendliest so far. Before you try and download the .net version try this one http://www.icsharpcode.net/OpenSource/SD/ it is free and much much smaller. It needs .net 3.5 with SP1. Once you have done this try the RS232 example here http://www.codeproject.com/KB/system/rs232ThreadSafe.aspx. You should download the sample and load it in the IDE.
I have just worked on this guys example to create a project for my colour sensor http://www.picaxeforum.co.uk/showthread.php?t=10415&highlight=avago to calibrate the tool. All it does is send a 1 or 2 to the picaxe and it runs the routine to match.
I fought with c++ and VB and I just can't make head nor tail of either but C# seems to make a lot more sense (from my PHP background I guess). Only down side I guess is the programs will be lashed to Windows but the same is true for VB.
Hope this helps someone fighting a similar battle.
