more code for serial port
also trhttp://www.devx.com/dotnet/Article/31001
http://www.dreamincode.net/forums/showtopic37361.htmhttp://support.microsoft.com/kb/904795/ this link is the best
these links or just search USING THE SERIAL PORT VB.NET AND YOULL GET HEAPS OF HITS
Imports System
Imports System.Collections.Generic
Imports System.ComponentModel
Imports System.Data
Imports System.Drawing
Imports System.Text
Imports System.Windows.Forms
Imports System.IO.Ports
_
Class Form1
Inherits Form
Public Sub New()
InitializeComponent()
End Sub 'New
Private stopBits, parity As Array ' arrays to access the enumerations in System.IO.Ports
Private validStopBits As New ArrayList() ' ArrayLists hold the valid values for this machine
Private validParity As New ArrayList()
' Send the text in the text box to the serial port.
' The data should stay in the buffer until received by the event handler.
Private Sub SendButton_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button1.Click
Try
' Write a line to the serial port
SerialPort1.WriteLine(textBox1.Text)
Catch ex As System.Exception
MessageBox.Show(ex.Message)
End Try
End Sub 'SendButton_Click
' Event handler for data reception
Private Sub serialPort_DataReceived(ByVal sender As Object, ByVal e As SerialDataReceivedEventArgs)
' Read the buffer to the text box.
textBox2.Text = serialPort1.ReadLine()
End Sub 'serialPort_DataReceived
' Load the form and set up parameters from the default serial port.
' Open the port and prepare it for IO.
Private Sub Form1_Load(ByVal sender As Object, ByVal e As EventArgs) Handles MyBase.Load
Try
' Open the serial port
SerialPort1.Open()
' Set the event handler for data reception
AddHandler SerialPort1.DataReceived, AddressOf serialPort_DataReceived
End Try
label11.Text = SerialPort1.PortName
label2.Text = SerialPort1.BaudRate.ToString()
label4.Text = SerialPort1.StopBits.ToString()
label6.Text = SerialPort1.Parity.ToString()
label8.Text = SerialPort1.DataBits.ToString()
label10.Text = SerialPort1.RtsEnable.ToString()
' Populate the stop bits box with all valid options.
' Note that the serial port must be open to accurately test the options.
comboBox1.SelectedText = SerialPort1.StopBits.ToString()
Dim currentStopBitSetting As System.IO.Ports.StopBits = SerialPort1.StopBits
stopBits = [Enum].GetValues(GetType(System.IO.Ports.StopBits))
Dim sbtype As System.IO.Ports.StopBits
For Each sbtype In stopBits
' test to make sure the machine supports the setting
Try
SerialPort1.StopBits = sbtype
validStopBits.Add(sbtype)
comboBox1.Items.Add(sbtype)
Catch ' ignore this entry as invalid
End Try
Next sbtype
SerialPort1.StopBits = currentStopBitSetting
' Populate the parity with valid options
comboBox2.SelectedText = SerialPort1.Parity.ToString()
Dim currentParitySetting As System.IO.Ports.Parity = SerialPort1.Parity
parity = [Enum].GetValues(GetType(System.IO.Ports.Parity))
Dim ptype As System.IO.Ports.Parity
For Each ptype In parity
Try
SerialPort1.Parity = ptype
validParity.Add(ptype)
comboBox2.Items.Add(ptype)
End Try
Next ptype
End Sub 'Form1_Load
' Respond to the form closing event by closing the SerialPort instance.
Private Sub Form1_FormClosing(ByVal sender As Object, ByVal e As FormClosingEventArgs)
serialPort1.Close()
End Sub 'Form1_FormClosing
' The following methods demonstrate the ability to set parameters of the serial port
' through the SerialPort instance. The baud rate of the port will be set in response to
' the corresponding button clicks.
Private Sub button3_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button3.Click
serialPort1.BaudRate = 1200
label2.Text = serialPort1.BaudRate.ToString()
End Sub 'button3_Click
Private Sub button4_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button4.Click
SerialPort1.BaudRate = 4800
End Sub 'button4_Click
Private Sub button5_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button5.Click
serialPort1.BaudRate = 9600
End Sub 'button5_Click
Private Sub comboBox1_SelectedIndexChanged(ByVal sender As Object, ByVal e As EventArgs) Handles comboBox1.SelectedIndexChanged
serialPort1.StopBits = CType(validStopBits(comboBox1.SelectedIndex), System.IO.Ports.StopBits)
label4.Text = serialPort1.StopBits.ToString()
End Sub 'comboBox1_SelectedIndexChanged
Private Sub comboBox2_SelectedIndexChanged(ByVal sender As Object, ByVal e As EventArgs) Handles comboBox2.SelectedIndexChanged
serialPort1.Parity = CType(validParity(comboBox2.SelectedIndex), System.IO.Ports.Parity)
label6.Text = serialPort1.Parity.ToString()
End Sub 'comboBox2_SelectedIndexChanged
End Class 'Form1
y ou go to vb forum, or do a search google using the serial port youlll find a downloadable file for this. It came from 101 examples zip file. or if you can give me yr emil i could send you the whole vb.net app i got this.
