It sounds like you may have an older version of Blockly. Later versions provide a comment block which can be used how you suggest.It is actually a Basic block in which you insert a semi colon before a comment.
To be more readable, what about the capability to add a comment beside the blocks like in the flowchart mode.
The only one I see is the Basic block at this place...Comment block is top block in advanced section.
Ok I get it. A question mark is added and a comment could be linked to it. Thanks.If you right-click on a block there is also an option to Add Comment to the block.
No. What Blockly core version is displayed (that is the 1.0.8 (in the grey bar top right of Blockly) in our screenshot above).I don't get it. The top block is still the Basic one.
Is there an option somewhere which may disable the comment block.
...that was. Thanks to all.pointing to an old beta test version
