Block Structured Programming is a mechanism to avoid using GOTO statements to make the logic of a program clearer, more understandable and easier to maintain and debug. It does not necessarily make programs any shorter, either in lines of code, nor code generated, can actually increase both.
You don't have to define 'blocks', simply use them, although you will have to enabled the Enhanced Compilers - View->Options->Editor.
The block structures supported by the PICAXE are ...<code><pre><font size=2 face='Courier'>FOR var = varOrNum TO varOrNum { STEP varOrNum }
statements
NEXT
IF var op varOrNum [ AND|OR var op varOrNum ] THEN
statements
END IF
statements
ELSE
statements
END IF
statements
ELSIF var op varOrNum [ AND|OR var op varOrNum ] THEN
statements
ELSE
statements
END IF
SELECT CASE var
CASE varOrNum [ , varOrNum ]
statements
END SELECT
SELECT CASE var
statements
ELSE
statements
END SELECT
DO
statements
LOOP UNTIL|WHILE var op varOrNum [ AND|OR var op varOrNum ]
DO UNTIL|WHILE var op varOrNum [ AND|OR var op varOrNum ]
statements
LOOP </font></pre></code>
In terms of editing 'blocks', these are simply sections of program which are prefixed by a '{' and end with '}'. When put into a program, the editor can hide and expand the parts in { ... } to alow some parts of the code to be hidden to make the rest more readable, for example ...<code><pre><font size=2 face='Courier'> FOR b0 = 1 TO 10
IF b0 = 1 THEN
GOSUB Multiply
ELSE
GOSUB Add
END IF
NEXT </font></pre></code> As can be seen, block-folding in the editing is quite closely tied to block-structures to be really effective. Also, correct indentation will help a lot. There is a whole eternity of debate we can have over whether the { and } should align with the outer block or statements within the inner block. My preference is as I've shown above, aligned with outer blocks.
