Bi polar stepper motor circuit
nick12ab
When I run this code in the simulator, I get an errormessage "Stack error - return without gosub!"
What code? There is no code on page 17 and the code on page 18 should not cause this. Please copy and paste the code you are using (don't just say it's the code from page x).
eclectic
Please alter the program slightly
Marked with ****
#picaxe 14M2
dirsB= %1111111  ; **********************
main: for b3 = 0 to 99 ‘ start a for...next loop
gosub lstep ‘ call left step sub-procedure
next b3 ‘ next loop
gosub rstep ‘ call left step sub-procedure
next b3 ‘ next loop
lstep: let b1 = b1 + 1 ‘ add 1 to variable b1
goto step2 ‘ goto the lookup table
rstep: let b1 = b1 - 1 ‘ subtract 1 from variable b1
step2: let b1 = b1 & %00000011 ‘ mask lower two bits of b1
lookup b1,(%1010,%1001,%0101,%0110),b2 ‘ lookup code into b2
let pinsB = b2 ‘ output b2 onto control lines ; ****************
e
Try adding a line
GOTO Main
or
DO : LOOP
Before the label LStep:
To stop the main code dropping through into the subroutines
EDIT:
(now at a PC)
#picaxe 14M2
	next b3 ‘ next loop
	next b3 ‘ next loop
	[B][COLOR="#FF0000"]GOTO Main [/COLOR][/B]; *-*-*-*-*-*-*-*-*
lstep:
rstep:
step2:
nerdegutta
Thanks.
I got it somehow working, but after a while the L293 gets really hot and the stepper stalls.
I've breadborded it, and I thought that the stalling came from no heatsink/fan and bad grounding.
- nerdegutta
boriz
"I got it somehow working, but after a while the L293 gets really hot and the stepper stalls."
Sound like you're using a regulator, something you didn't mention earlier, probably an L293, probably trying to operate it beyond spec, probably didn't read the datasheet?
To avoid confusion and guesswork can you please post:
1. A link to the Datasheet for the stepper motor or failing that the voltage and current details
2. A schematic of the circuit you have constructed
3. If possible a photo showing clearly the project preferrable taken perpendicular to the board with a clear background so folks here can trace/ check your wiring
4 the PiCAXE program code as you have to so far.
Overheating could be due to:
1. Excessive current draw -the now mentioned L293D is rated at 600 mA
2. Wrong control of the driver chip - in effect creating an internal short ?
3. Wrong wiring
nerdegutta
Hi.
1. Link to stepper motor.
3. No camera available at the moment... :(
4. The code:
#picaxe 14m2
#no_data
symbol dir_pin = pinc.0
symbol step_pin = pinc.1
dirsB = %1111111
if dir_pin = 0 and step_pin = 1 then
	let b1 = b1 + 1
	gosub step2
if dir_pin = 1 and step_pin = 1 then
	let b1 = b1 - 1
	gosub step2
'  	low b.0:low b.1:low b.2:low b.3 ; testing
' lookup b1, (%0000, %0000, %0000, %0000), b2 ; testing, turning all pins off
let pinsb = b2
step2:
	'lookup b1, (%1010, %1001, %0101, %0110), b2 ; testing
	'lookup b1, (%1100, %0110, %0011, %1001), b2 ; testing
 	lookup b1, (%1010, %0110, %0101, %1001), b2
	let pinsb = b2
Thanks for your time!
- nerdegutta.
The problem is the motor current.
From the techncial data for the motor:
Technische Daten:
- Betriebsspannung max. 5 V- = voltage rating
- Strangstrom max. 1 A = current rating
You are running the motor at 12 Volts DC but is only rated at 5 Volts so the current will in fact be roughly twice that stated.
The nameplate motor current rating is 1 Amp however the L293D is only rated for 0.6 Amps continuous with brief peak current to 1.2 Amps.
Yet because of the 12 Volt supply your pulses will be around 2 Amps so almost double the L293D peak rating.
As an experiment:
1. reduce the voltage on the L293D Vcc2 pin (pin8) from 12 V to 5 volts and the chips should not get as hot.
then if still warm try
2. add a 4.7 Ohm resistor in series with the 5 V supply to the Vcc2 pin to limit the motor current to around 0.5 Amps. The motor may operate a little slower and need more time delay between steps. The L293D should definitely not be hot now.
then to operate properly:
3. Find a 5 or 12 V motor with a current rating less than 0.6 amps (600 mA)
Certainly the website indicates 5 V rating.
Are there any marking on the motor?
If not and if you have a multimeter then measure the winding resistance.
Is it 5 Ohms?
Neglecting the motor reactance, the current (Amps) will be Volts / Ohms.
That will indicate the current at 5 V and 12 V? Anything greater than 0.6 Amps is going to add to the heating and possible failure of the L293D.
nerdegutta
It certenly does.
AEG S026/48
253/0.4 4C 01
Is it 5 Ohms?
Yes, 5.3 and 5.4
I replaced the 12v with 5v, and then the motor stalls. I also tried with a Pause-command, from 10 to 100. After the lookup in Step2. Still stalling.
- nerdegutta
nerdegutta
Added a video
First part is with 5v on pin8, last part is with 12v.
[video=youtube_share;F3lEvAjwgVQ]http://youtu.be/F3lEvAjwgVQ[/video]
- nerdegutta
Looking at your video, the stepper motor is operating in one directionon 5 V but seems not to reverse.
As expected, the motor operates faster with the higher voltage and can reverse direction.
Some site I looked on a couple of days ago sugegsted that the AEG model you have is not a particularly good quality motor.
I also found some site indicating a rating of 10V and 0.65 Amps with 15 Ohm windings.
Seems it is not your program or the driver chip (L293D) but more likely the quality of the motor.
