Hi All!
Happy New Year!!
I want to replace some project inputs from open/close switch to something that uses less inputs. Currently it uses a 28x1 and I have 9 inputs to read from. I was wondering if A range finder can be used instead of all the switches?
The way it works it's like a bean bag toss board game, instead of one target hole it's has 9 and it uses baseballs.
When the baseball go through the target it actuates the switch adding points for that target. But becouse the way the ball is thrown to the target the switches started to fail.
So I thought why not use and HC-SR04 range finder?
Installed at one end where it can cover all 9 holes & according to the distance where the holes line up the 28x1 add up the points.
Do anyone Else have a better approach?
Maybe a better sensor?
The goal is to use the least switches possible.
Thanks!
Happy New Year!!
Thanks!
