Hello,
I am having some trouble with my download circuit:
Symptom: Doesn't work (gives device not found error in Program Editor)
Cause: Well, I don't know (or I wouldn't be posting this ), but I think I might have swapped Ground and Serin (serout laptop to serin Picaxe).
In the Manual 1 Page 5 or 31 it gives the circuit which I replicated. I have used the tech supplies 3,5 mm connectors (as shown in the manual) to connect the serial download cable to the board. In the manual it states "above view" (component side of the board?), with serin (of Picaxe) connected to the pins on the right side of the serial connector. On the track side positions will be reversed so serin will be on the left side.
When I measure the voltage (with connected serial cable) between ground (black lead of multimeter) and serin (red lead of multimeter) I get about - 4,5 V; with or without battery pack connected (I am pretty sure I got those connections right )
I assume I should get a positive voltage. Have I misinterpreted "above view"?
I have build this circuit twice, used two different 08M, checked the circuit for shorts, and downloading programs to a 40X1 (on the RevEd Protoboard) works a treat. The circuit is powered by 3 AA batteries.
Three "untouched" 08M left.
Any suggestions are welcome.
Regards Florian
Regards Florian
