I recently purchased a led042 GLCD, everything seems to to work ok but there is no backlight on the glcd. I have measured the voltages going to the back light pins and found the following: on K =+2.73vdc, A=+4.98vdc, -v= -4.88vdc. Also, to see the anything on the display, the contrast pot has to be fully in the ccw direction. The display characters are a gold color. I have checked connections etc and everything appears correct. Is there a software function I am not aware of? Or do I have a bad display. The V=+2,73v seems wrong to me but it is more negative than A. Thanks to any responders!
Thanking you,
Earl
Thanking you,
Earl
