D dandlion New Member Feb 5, 2014 #1 This may be a dumb question - but - I've studied the pin-out diagram very carefully and I can't find a Shield Header pin for the 28X2 hardware pin 7 (or Pin A.4). Where did it go? (The one labled "TXD" on the chip diagram).
Technical Technical Support Staff member Feb 5, 2014 #2 This pin is in the 3.5mm programming jack socket on the base, it is not one of the pins that go up to the shield.
I inglewoodpete Senior Member Feb 6, 2014 #4 You can still use the pin. It's just that it won't appear in the shield's bus connectors, if you should want add a simple plug-in shield.
