shah_siddiquee
Hi, i am making a wireless communication using axe 213 wireless boards. My transmitter and receiver board are working fine. I can transmit data using 08m2. And i can receive that data from the receiver board using sereal monitor on computer. I put the sereal cable direct to the receiver board jack socket. But the problem is, when i try to get that data using picaxe 08m2, it doesn't show anything on the sereal monitor. As i said everything is working fine, i mean , LEDs are flashing on both RX and TX board correctly. I read the axe213 datasheet several times. I did, all is says. I tried one wire interface, i tried two wire interface, but nothing works. Anyone please help. I watched the debug window. It shows the data onece and remains same. Any kind of help will be appreciated. Thanks
