mrburnette
Continued on: AXE13Y Clock Battery Backup
Continued from: http://www.picaxeforum.co.uk/entry.php?46-Hack-OLED-AXE133Y-to-upgrade-18M2-to-a-20X2-PICAXE
The port of the 18M2 to the 20X2 was very simple and building a daughter-board for the AXE133Y was very simple, too. In this installment, I enhance the code to support the AM/PM indicator and to display in non-military time... this model is going on my wife's night stand and she asked for the change... a matter of preference. So, I decided to post the entire code in case anyone wanted to cannibalize some of the routines.
The 20X2 codebase (OLED support + time 'n display + temperature) is now at 38% with plenty of room left for additional code... and I have at least 500mS of free time to play around with at present before the time-critical loop must recycle.
Old Concept:
Previously, I had the following crude code running in a loop which executed every second:
Not all that elegant, but it works. The associated display code for the OLED look like this:
In contemplating the AM/PM implementation, I had wanted to just carry a sum of seconds for 24 hours:
24hours x 60mins/hour x 60secs/min = 86400... Oops! Too big for 16-bits.
So, I fell back to summing the minutes for 24 hours:
24 x 60 = 1440 minutes which is a nice figure for a PICAXE word value.
The new code looks like this:
And the associated display routine appears as:
With Valentine Day coming up, at least her clock will display in the manner she desires... now, just to make those dinner reservations!
- Ray
Note: When setting with the "sony-ish" IR remote control, military time format must still be utilized. Somewhere in the future, I'll add a soft-option for 12/24 hour display.
Old Concept:
secs = secs + 1 // 60
If secs = 0 Then
mins = mins + 1 // 60
If mins = 0 Then
hour = hour + 1 // 24
EndIf
EndIf
Case 2 ; Called every second to update time on OLED bottom line1
;_____RAM MAP________
;55556666666666777777
;67890123456789012345
;sfcc....HH:MM:SS.... s=start, f=finish, c/c=control_bytes
POKE 58,254,192
Line = 1 : GoSub DisplayRAM
POKE 58,0,0
If hour = 0 then
; EQ = serout Serial,BAUD,(" 00:")
POKE 64,"0","0",":"
elseif hour < 10 then
; EQ = serout Serial,BAUD,(" 0",#hour,":")
tempL = hour + 48
POKE 64,"0",tempL,":"
; EQ = serout Serial,BAUD,(" ",#hour,":")
tempL = hour //10 + 48
tempH = hour / 10 + 48
POKE 64,tempH,tempL,":"
endIf
If mins = 0 then
POKE 67, "0","0",":"
elseif mins < 10 then
tempL = mins + 48
POKE 67, "0",tempL,":"
tempL = mins //10 + 48
tempH = mins / 10 + 48
POKE 67,tempH,tempL,":"
endIf
If secs = 0 then
POKE 70,"0","0"
elseif secs < 10 then
tempL = secs + 48
POKE 70,"0",tempL
tempL = secs //10 + 48
tempH = secs / 10 + 48
POKE 70, tempH, tempL
endIf
GoSub DisplayRAM
hours = tMin / 60
mins = tMin // 60
IF tMin > 719 then
AmPm = 1 ; afternoon
Else
AmPm = 0 ; morning
EndIF
Disp2:
;sfcc.?M.HH:MM:SS.... s=start, f=finish, c/c=control_bytes
POKE 58,254,192
POKE 58,0,0,32,80,77 ; clear control info and poke " P" in pos 61
IF AmPm = 0 then
POKE 61, 65 ; "A"
EndIF
tempH = 32 ; space
IF hours > 12 then
hours = hours - 12
endIF
;EQ = serout Serial,BAUD,(" ",#hours,":")
IF hours > 9 and hours <=12 then ; display 2 digits: 10, 11, 12
tempH = 49 ; "1"
endIF
tempL = hours //10 + 48
IF mins = 0 then
elseIF mins < 10 then
tempL = mins + 48
EndIF
IF secs = 0 then
POKE 70,"0","0"
elseIF secs < 10 then
tempL = secs + 48
POKE 70,"0",tempL
EndIF
GoSub DisplayRAM : Return
- Ray
