I am trying to configure an axe133 using the winstar 4x20 OLED to communicate as fast as possible with my main 40x2 which is going to run at 64mhz.
I am hearing through other posts that the max speed is 4800 baud. If that is the case I need to slow down the main pic down to 32mhz as that is the fastest speed that will run 4800 baud.
So this is what I did:
40x2 runs at 64mhz, except when writing to the LCD. The routine that writes to the LCD starts with a setfreq em32, sends out data at N4800_32, then the display routine ends with a setfreq em64.
The LCD, I just insert a setfreq m32 just 'above' the "main:" routine in the 18M2 micro, I leave the default N2400 'as-is', as the setfreq m32 will double the speed anyways.
When I run this, the screen is garbled.
Can anyone suggest what I may be missing? I am running the 40x2 with an external 16mhz oscillator, the only thing I am thinking could be the problem is the ocillator might not be working correctly, hence the timings will be off.
Any other ideas or suggestions?
John
John
