I just received my new data logger and hooked it up per the instructions. I am using an DS18B20 input sensor and a AXE133 real time display. I also have the AXE034 clock and 24LC256 EEPROM.
I am using PICAXE editor 6.0.7.5
Here is the problem:
I open the editor and select NEW program. Next I open the wizard and check the appropriate boxes and hit close. Nothing happens!!!!
I would expect to see the code generated on the screen, but nothing appears and the OLED display shows the standard greeting. What could I have missed? Should I be able to see the code generated in case I want to hack a custom application?
