Hi.
I am using the AXE110 Data logger to log temp/light in my glasshouse
If I set logging period to pause command it works ok, But setting it to DS1307 RTC it will not record the readings, Am using the Wizard to set the mission, I do have the DS1307 chip in place and the backup battery, Have sent the DS1307 program and cleared picaxe memory before sending the mission, The green led flashes at 1Hz, Is there something else I should be setting any help would be appreciated.
Regards,
Ted.
Regards,
Ted.
