wijnendael
Just received my picaxe kits and given them a test run, the logger works great but have a question regards using the datalink in PE6 beta. If i use the data link in PE5 i can display the graph but in PE6 no graph is displayed and there are no menu tabs at the top of the window is this normal ? or is it simply because it is a beta version. Finally on another note (not same kit but received at same time) I also purcahased the Axe213 rx and tx boards to give my rf part a test, when assembling the boards i found that all the holes are drilled the same size so the headers will not fit without opening up the holes to the correct size. This was not a great task but thought i would mention it so others know or it is fixed on the next batch.
