wijnendael
Just got my 20 x 4 oled display and trying to configure the code file from the default 16 x 2 and not really sure if i have a problem or not. Can you still use the same number of messages as the 16x2 setup as i keep getting a error when it gets to message 12, i have changed the length of the message and the start addresses but will only work up to the message 12 am i missing something here or simply done something incorrectly. This is how i changed the code:-
[/CODE]
[CODE]#ifdef use_OLED
EEPROM $00, (" Serial OLED ") ; store msg in the EEPROM memory
#else
EEPROM $00, (" Serial LCD ") ; store msg in the EEPROM memory
#endif
EEPROM $14, (" 20 chars ") ; store msg in the EEPROM memory
EEPROM $28, (" version 1 ") ; store msg in the EEPROM memory
EEPROM $3C, (" .com ") ; store msg in the EEPROM memory
EEPROM $50, ("This is msg 4 ") ; store msg in the EEPROM memory
EEPROM $64, ("This is msg 5 ") ; store msg in the EEPROM memory
EEPROM $78, ("This is msg 6 ") ; store msg in the EEPROM memory
EEPROM $8C, ("This is msg 7 ") ; store msg in the EEPROM memory
EEPROM $A0, ("This is msg 8 ") ; store msg in the EEPROM memory
EEPROM $B4, ("This is msg 9 ") ; store msg in the EEPROM memory
EEPROM $C8, ("This is msg 10 ") ; store msg in the EEPROM memory
EEPROM $DC, ("This is msg 11 ") ; store msg in the EEPROM memory
;EEPROM $F0, ("This is msg 12 ") ; store msg in the EEPROM memory
;EEPROM $104, ("This is msg 13 ") ; store msg in the EEPROM memory
;EEPROM $118, ("This is msg 14 ") ; store msg in the EEPROM memory
;EEPROM $12C, ("This is msg 15 ") ; store msg in the EEPROM memory
