Hi, after getting my code for the AXE033 LCD display to work in the simulator (great invention) I received my AXE033 kits. After putting one of these kits together and plugging into my picaxe28x1 I do not get any messages on the screen - even if I short the clock pins as suggested. There is no clock module attached.
I have checked all of the solder joints and they look very clean and no obvious connections to more than one pin. However, when I check with a ohmmeter I have some interesting connections. I soldered the headers directly between the 2 boards. I am driving with a 5VDC supply and I get 5V at the input header.
Looking at the connections on the LCD side (on the left) and checking with ohmeter to the pcb side I see the following connections to the PCB side (right pins)
lcd pin1=pcb pin1
lcd pin2=pcb pin2
lcd3=connects to pcb 1,3,5,7,8,9 and 10
lcd4=pcb4
lcd5=pcb 1,3,5,7,8,9,10
lcd6=pcb6
lcd7=pcb 1,3,5,7,8,9,10
lcd8=pcb 1,3,5,7,8,9,10
lcd9=pcb 1,3,5,7,8,9,10
lcd10=pcb 1,3,5,7,8,9,10
lcd11=pcb11
lcd12=pcb12
lcd13=pcb13
lcd14=pcb14
Can anyone tell me if this should be expected (looking at a working unit) and, if not what could be causing this? I want to solder the other unit but not without checking this one works first. With the 2 headers soldered this will be VERY difficult to disconnect.
Thanks for your help.
Evans_US
lcd pin1=pcb pin1
lcd pin2=pcb pin2
lcd4=pcb4
lcd6=pcb6
lcd11=pcb11
lcd12=pcb12
lcd13=pcb13
lcd14=pcb14
Evans_US
