noelnelson
My AXE027 USB programming cable has just died. It just didnt work when the laptop was turned on and programming editor started.
Then, when I tried it in another USB port, Windows told me there was excessive load on the USB hub, and both my USB ports are now also dead.
Apart from seeking sympathy, has anyone experienced this or have a comment?
(ASE027 was plugged into laptop and the project, when laptop tuned on. And I have used the same cable for many projects)
I have previously noted that my picaxe project can re-boot sometimes when plugging in at the 3.5mm plug end, if the laptop is powered from the mains plug pack. I suspect the floating DC output from the laptop plugpack (Switchmode unit) is the culprit.
