Hi all hope someone can help.
When I started using PICAXE chips some months ago I bought an AXE027 lead and used it successfully for some time. Quite recently it has resolutely refused to program any of my project boards which include 8M2, 18M2 and a 20X2 homebrew board. In every case it says cannot find the hardware on the COM Port the usual message it seems.
I have tried the test and the voltage goes high and low as needed. Putting a scope on the Pic Axe is receiving something from thr AXE 027 and is responding with a signal. The PC running windows 7 does not respond and I get the error message hardware not found on com5 (which is where it is). I have selected the correct com port every time.
I have tried the driver, loaded them several times. The paper clip tests works and I receive what I send back in the terminal window from the axe 027.
I have a separate usb serial converter and I have wired a lead up go with that. Using the Prolific USB Serial converter I can program all my chips no problem first time every time but I cannot with the AXE027. It will not and as I say I get the error message about the hardware on the com port. I have noted the comments regarding decoupling capacitors and they are fitted to all my boards, I use a regulated 5v supply and i have tried a battery box too. No good.
The AXE027 does not appear to be fault as the paperclip test works. Could it be levels but on the scope they look OK.(5V)
Help please!!!!!!!!
Help please!!!!!!!!
