You may be thinking, "Can he not read the data sheet where it says Input 3 is the one and only input on the AXE023 board?" I read it, but I just want to make absolutely sure...
My project requires forward/reverse/stop control of one motor, and two inputs. For those of you familiar with the AXE023: is there anyway to use the output I am not using to wire up an input? I know on the 08M some of the pins can be inputs or outputs, depending how you call them in the code.
Thanks.
EDIT: One of the inputs would be IR in, the other would be a contact switch.
Thanks.
