pleiser
Hi I made a wireless weather station (forum post here http://www.picaxeforum.co.uk/showthread.php?20646-weather-sensor-problem )
and until now I was using debug but I am now trying the axe213 rf boards ( http://www.picaxe.com/docs/AXE213.pdf )and found the transmitter is not working (or at least led is not blinkind when test button pressed and reciver is not reciveing anything) I am getting 5 (4.98) volts on the transmitter +volts and ground pins. On the pins for the transmitter( http://www.picaxe.com/docs/RFA001_TX.pdf ) I am getting 1 (1.03) volts I dont think this is normal because the datasheet says it works from 1.5 to 5 volts.
any ideas how to fix this?
Patrick
Patrick
