I've tried Initial Setup Procedure and the Xbee modules only work at 9600.
Then I've tried Communications Test 1 – Ping Test at 9600 and it works.
Finally I've tried Communications Test 2 – PICAXE to PC Test and oly get garbage (incomprensible simbols).
My Picaxe is 18A. After same reading I've supposed if I wrote the next program:
It could work. But the editor shows the next:
I'm very confused. According to
http://www.picaxeforum.co.uk/showthread.php?t=9780&highlight=2400+4800+9600+19200
it seems pausible.
Thanks
symbol TAB = 9
init:
setfreq m8
high 7
pause 100
serout 7, T9600, ("Light",TAB,"Temp",CR,LF)
main: readadc 0,b0
serout 7, T9600, ( #b0,TAB,#b1,CR,LF)
Error: Unknow symbol! - T9600
it seems pausible.
Thanks
