Just a thought - could the editor automatically add end-of-line comments after certain commands, such as:
1. after a goto or gosub label copy a comment from the label in the program, e.g. if I enter:
gosub LcdOut
LcdOut: ' send character in b0 to the LCD
then it might automatrically make the gosub line:
gosub LcdOut ' send character in b0 to the LCD
This is something that an old Data General BASIC did, which was a good aid to readability.
2. indent for/next loops nicely, based on the nesting level
also an idea from DG Business BASIC
3. if peek/poke a constant location is used, add a comment from an external, user-edittable text file that has a comment per location for each picaxe model?
4. optionally add a comment after each IO command that references a pin and say the "leg" number (for the selected picaxe chip) or the standard register pin name (e.g. RA2), or allow the programmer to give the leg number or any of the other common names that identify the pin, e.g. "hpwm D" and have the port name shown as a comment?
Note that I think the documentation can lead people to make errors too easily; this would help avoid some of that. For example, the documentation for pwmout, page 115, says to use pin 2 on a 14M, and says to see the pinout diagram, yet neither the diagram on page 70 of manual 1, nor that on page 20, shows anything called "port 2"... there is input 2, output 2, C2, etc. If programmers could be given the option of specifying the leg (e.g. high leg7) and the compiler does the translation for code generation (e.g. high portc 3 'leg7 on 14M) that could aid clarity. Related to that: I see you can sometimes write: portc pin0 (for inputs)... why can't we write "portc pin0" or "portc 0" or "port c0" or "pin C0" or even "RC0" for any input or output statement? Standardisation on one form would be nice, of course, but it is also important to clearly relate software to hardware naming conventions (of which there are several).
5. perhaps as an option when printing programs, have label cross-reference tables, statistics such as code size per section of code, etc... becoming more important as larger programs become possible with the bigger chips. This (and auto-indentation, etc) could be implemented simply by allowing a post-processing filter to be specified when printing.
Mark
gosub LcdOut
Mark
