I just want to check with assembler code stuff that have not been referenced in the assembler manuals. (PE 5.2.6)
Are symbol definitions e.g. INTCON, PIR1 really case sensitive?
How do I type in decimal numbers, binary numbers, and hex numbers?
I see numbers like
B'10000110'
d'04'
h'20'
H'000C'
H'0081'
H'008D'
in the numbers prefixed H, the hex letter digits dont show the number colour like the other digits do.
Is that how I am supposed to enter numbers into e.g. for the k value in commands like 'movlw'?
Secondly, in the PIC16F819 manual at section 3.3, the example code 3-1 has "BANKSEL EEADR" at the start, where BANKSEL appears pink. Is this really valid?
Thirdly, PE hasn't included assembler templates for the PIC16F87/88 and for the PIC16F88x family yet.
Thanks, TC
edit: currently, PE doesn't seem to support filenames including it's path that is longer than about 62 chars, so I can't put assembler files in
C:\Users\Toby\Backup of Toby NANO\PICAXE files\assembler progs (where Backup of Toby NANO is synchronized with my flash drive).
I would suggest PE should fit file names into the window bar like this:
C:\Users\Tob...assembler progs\prog1.bas (where the bit after the ... only starts to colapse if the bit before ... has collaped all the way down)
Or like this:
C:\User...E files\assembler progs\prog1.bas (where the bit before ... always shows C:\ and 4 more chars of the start of the path)
Rather than just:
C:\Users\Toby\Backup of Toby NANO\PI...
so that I can't see the actual file.
(well, I'm not sure if this could be done on the name header in sub-windows inside the PE window - probably easier for it to just show the filename, and have an option to just show the filename, or show the full path of the file.)
