Thanks for having a dig around for me. I'm not able to see version info for qemu...
I will go through the forum post you linked so I understand more about what could be the problem. I have run the 4 commands you suggested, I think it's shifted the issue onto something else...
I'm wondering if there is a bunch of 32-bit stuff I don't have on my machine. libgthread-2.0.so.0 is there but I get the original unhelpful error message...
This isn't terminal for my picaxe days as I do have an old laptop I can run PE6 on.
pi@raspberrypi:~/Documents/picaxe/picaxe/bin $ ./qemu-i386 -version
bash: ./qemu-i386: No such file or directory
pi@raspberrypi:~/Documents/picaxe/picaxe/bin $ ./picaxe08m2 -h
./qemu-i386: error while loading shared libraries: libgthread-2.0.so.0: cannot open shared object file: No such file or directory
pi@raspberrypi:~/Documents/picaxe/picaxe/bin $ file /usr/lib/aarch64-linux-gnu/libgthread*
/usr/lib/aarch64-linux-gnu/libgthread-2.0.a: current ar archive
/usr/lib/aarch64-linux-gnu/libgthread-2.0.so: symbolic link to libgthread-2.0.so.0
/usr/lib/aarch64-linux-gnu/libgthread-2.0.so.0: symbolic link to libgthread-2.0.so.0.6600.8
/usr/lib/aarch64-linux-gnu/libgthread-2.0.so.0.6600.8: ELF 64-bit LSB shared object, ARM aarch64, version 1 (SYSV), dynamically linked, BuildID[sha1]=e56f4cbb202b0860e3e378d5dcfcca6a8880290d, stripped
