I've followed the Xbee tutorial pdf.
I want to get PICAXE to PICAXE communication working.
HARDWARE.
I have two XBee modules set to a BAUD rate of 4800 and two PICAXE 18X chips.
THE PROBLEM
This is very strange. I have one board sending out the character "A" every second. The Receiving board only works when I connect PIN7 to another input pin using a long piece of wire (atleast 10+cm, doesn't work with a short piece).
I've looked at input pin7 on an oscilloscope and it is receiving the data. As I said, very strangely, the board/code only seems to work, when input pin7 is connected to another input pin via a long wire.
One would assume, that using a short piece would work but NO!
'--SENDER CODE:
init: setfreq m8
pause 100
main: serout 7, T4800_8, ("A")
'--RECEIVER CODE:
init: setfreq m8
main: high 0
serin 7, T4800_8, ("A")
low 0
Is it the board or am I doing something wrong?
Cheers
K
HARDWARE.
THE PROBLEM
'--SENDER CODE:
init: setfreq m8
pause 100
'--RECEIVER CODE:
init: setfreq m8
main: high 0
low 0
Cheers
K
