AND / OR function with variables
russbow
I want to call a sub routine if a variable is zero OR 5 and another variable is 1
if b8=0 or b8=5 and flag=0 then gosub count_it
that is if b8=0 and flag=0 then gosub also if b8=5 and flag=0
Also would this work to re-set flag for b8 values of 1,2,3,4 - 6,7,8 or 9
if b8<>0 and b8<>5 then let flag=0
It passes the syntax but I just don't feel comfortable with it.
For anything that is not goto or gosub you should use a multiline structure:
let flag=0
end if
nick12ab
let flag=0
end if
And anything within a DO : LOOP or an IF statement should be indented. If there's labels in use, it also looks neater if everything is indented.
        let flag=0
    end if
russbow
Thank you both.
It is
that I need reassurance with.
Does this equate to
if b8-0 and flag=0 then gosub
if b8=5 and flag-0 then gosub
I can read this as
if (b8-0) OR ( b8=5 and flag=0 )
MPep
        let flag=0
    end if
Not necessarily, but certainly aids in readability. More experienced programmers WILL use this because it makes fault finding easier. :)
