Hi there. I’m working with a strain gage which gives no more than 10 mV. Given that the Picaxe analog input receives voltage around [0-5v]. I need to get a small this signal amplified from [0-10mV] to [0-5v]
I don’t want to use transistor configurations because the amount of elements needed and the inexact signal obtained with it. I neither want to use op-amps because a (-) alimentation font would be needed to feed the op-amp.
Any of you guys know a high gain amplifier C.I. which works with low energy (5-12V)?
