Data Logger and Air Conditioner Control
I've just built a wine cellar room and would like to fit it out with something to monitor the temperature and humidity in there plus control the split system air conditioner that cools the room. I was looking at using a Picaxe and associated components and I wanted to know if I could do the following with it or if I am over-complicating things:-
• Four temperature probes
(1) & (2) Two located inside wine bottles filled with water to give the closest possible reading to the temperature of the wine – in two different parts of the cellar, logged over time
(3) One located inside the cellar measuring the air temperature – to control the split system air conditioner which provides the cooling. This one is required as the split system air conditioner will only cool down to 18 degrees C out of the factory – would like to disconnect the thermostat on the unit and connect it up to the cellar one – perhaps using an offset to trick it to run cooler
(4) One located outside the cellar measuring the air temperature
• Two humidity probes (not essential)
(1) One located inside the cellar to measure the humidity
(2) One located outside the cellar to measure the humidity
• LCD display would be mounted on the outside of the room so I can see the current temperature in there when walking past
• All of the measurements logged and then somehow periodically upload the data from the data logger to a PC
- Either have the PC on all the time and do it at regular intervals – advantage of this is that I could log in remotely and see what is happening but this is not critical
- Ideal would be for the data logger to transmit the data to the PC whenever it happens to be turned on – PC is in our study and it is usually turned on every couple of days
I think the options I have are:-
• Measurement, data logging and air conditioner control all done by Picaxe
• Stand-alone data logger feeding data to Picaxe which then controls A/C
• Stand-alone data logger feeding data to a PC running some sort of application which then controls the A/C
Work I am trying to work out is if this is over-complicating things by trying to do it all in a Picaxe, especially as I am no electronics whiz….
I would appreciate any suggestions as to what people think is the most logical, simple and reliable approach at a reasonable cost.
Many thanks
Chris
Many thanks
Chris
