terrapinlogo
I have a keypad and led display that I have pulled from an old house alarm and I am trying to get the display half going with a 20X2 (haven't tried the keypad half yet). But I am having no luck. I can clock the data in manually by connecting the clock and data lines to ground but I cannot get it to work with the 20X2. Here is the code that I have been trying:
I found the original code on this forum somewhere and then modified it for hspi and to transmit 16bits instead of 8
symbol clock = b.7 ; clock on b.7
symbol pattern = w0 ; variable to hold the LED pattern
symbol delaytime = b15 ;variable to hold the delay beetween changes
init: low clock ;Set up the chip and outputs etc
pattern = %0000000000000001
delaytime = 1
hspisetup spimode11, spislow
output b.7
main: ;Change the pattern then
DO
GOSUB out_595 ;gosub to output the data
pause delaytime
pattern = pattern <<1
loop until pattern=%1000000000000000
DO
GOSUB out_595
pause delaytime
pattern = pattern >>1
loop until pattern=%0000000000000001
out_595: ;transmit the data to the board
hspiout (b1)
hspiout (b0)
