I recently bought some high power LEDs to augment the counter-top lighting in the kitchen. When I bought the LEDs I looked for something that was fairly bright, was the right colour (I got some white warm, and some white neutral) and that was fairly cheap. I ended up buying Cree MX-3 LEDs, depending on the colour of the LED they are about ~$1.3 US apiece, put out ~90 lm apiece and have a viewing angle of 120°. I bought seven of each, which I think should be enough for about 5.3 m2 of counter/sink/stove space. I want the warm coloured LEDs over the stove-top and the neutral LEDs over the sink, with mixed colours over the actual tiled counter.
I had originally thought of using a LM317 paired with each LED as a constant current driver, along with a high power transistor attached to a Picaxe for PWM control but I soon found out that they warmed up quite a bit, even with a substantial heat sink. While I think I could still use the LM317 and high power transistor as a driver and for PWM-ing the LED, I was looking for a better way of driving the LEDs, preferably with one chip with the driving and PWM-ing circuitry all built in. I found what I think is a pretty good driver, but I want to make sure that it is suitable for my intentions. It is the AL5801W6-7 and costs about $0.50 US apiece in quantities of over ten on Digikey [http://www.digikey.com/product-detail/en/AL5801W6-7/AL5801W6-7DICT-ND/3481118].
There is one main question I have about the chip however. The Cree MX-3 LEDs [http://www.cree.com/~/media/Files/Cree/LED%20Components%20and%20Modules/XLamp/Data%20and%20Binning/XLampMX3.pdf] are rated for a maximum of 400 mA at about 3.8 V but as they are quite bright I want to power them at a more modest current, around 300 mA or so. On page six of the datasheet [http://www.diodes.com/datasheets/AL5801.pdf] Figure 12 shows the relationship between Output Current and VOUT. I'm not quite sure what exactly that chart means, but I am thinking that it may be a chart of the maximum current output at a certain voltage and vice-versa. In this case, if I wanted to run them at 300 mA there wouldn't be enough voltage, and again vice-versa. Am I misinterpreting this graph or is this a correct assumption?
One more small question. The datasheet for the AL5801W6-7 shows two circuits that can be used to PWM the LED. I think I would go for the one that uses a 2N7002 MOSFET because of the smaller quantity of parts. However, it doesn't mention any specifics for the MOSFET and looking up '2N7002' on Digikey returns a myriad of results. What general sort of specifications should I be looking for on the MOSFET or does it not make much of a difference?
Lastly, if anyone has suggestions for other cheap, small and simple LED drivers that are PWM-able, I would love to hear them. I'm used to using a resistor, and this is my first foray into high-power LEDS .
