Iam sniffing volts from battery and want to switch relay when volt ar >x or <x. What is best way to simulate,test this, like if volt > 571 then high one relay, if volt < 545 then high other relay, need your advice what is the simplest way to simulate this, whether you can send a command via the terminal without messing with hardware?
