Need to input r/c receiver pulse 1 to 2 ms and use this to generate a proportional out voltage. I have thought about generating a mark/space signal as an output and then perhaps smooth it with a cap. Much like a flashing led. Question is........ other than the scan rate would there be other things to consider? If i keep the mark space at say for example 300/170ms rather than 30/17, I thought the scan rate would be less of an issue.
or should that be DAC out..
