Hi Wiliam, depends on how skinny that wire is and how many amperes the power supply can put out
FROM Tech supplies:
FRM050 L293D PWM Driver
The PWM Driver firmware is a special 8 pin chip designed to drive a L293D
motor driver chip to add speed control without any extra output pins.
As used on our AXE120 microrobot system.
£3.00 £3.60 (inc. VAT)
At that price it's probably better to use a PICAXE with more capability for output pins... You can make a direct link from the PICAXE to the L293....
So the chip not identified in the diagram is a special PIC programmed and available from RevEd...
