A Maths Question
neiltechspec
Yet again I seem to be struggling with maths.
Built a Wideband AFR guage that displays 0v to 5v as 10 to 20 AFR.
This used,
    readadc sens,adc
    afr = adc*20/51+100 max 199     'max  value limited to 19.9
    bintoascii afr,b10,b11,b12
It worked well enough.
Now I have changed the Lambda Controller.
This gives from 0v to 5v as 7.35 to 22.39 AFR, supplier says to convert Volts to AFR use - V*15.04/5+7.35.
So I have tried, afr = adc * 10 / 51 * 15 / 5 + 73 max 199
But this seems to give large jumps between readings.
Any suggestions on the maths.
Have subsequently come up with this below, untested on H/W yet though
    readadc10 sens,adc
    afr = adc / 2 * 15 / 5 + 735 max 1999
    bintoascii afr,b10,b11,b12,b13,b14
    'sertxd(#adc," ",b11,b12,b13,cr,lf)
This may help ...
afr = adc * 1504 / 255 + 735
afr = adc * 5.898039215686275 + 735
afr = (adc * 5) + (adc * 0.898039215686275) + 735
afr = (adc * 5) + (adc * 0.898039215686275 * 65536 / 65536) + 735
afr = (adc * 5) + (adc * 58854 / 65536) + 735
afr = (adc * 5) + (adc ** 58854) + 735
Symbol adc = b0
Symbol afr = w1
adc =   0 : Gosub CalcAfr
adc =   1 : Gosub CalcAfr
adc = 254 : Gosub CalcAfr
adc = 255 : Gosub CalcAfr
End
CalcAfr:
  afr = adc *  5
  afr = adc ** 58854 + afr + 735
ShowAfr:
  b13 = afr / 100
  b12 = afr / 10  // 10
  b11 = afr       // 10
  SerTxd(#adc, TAB, #afr, TAB, #b13, ".", #b12, #b11, CR, LF)
  Return
0       735     7.35
1       740     7.40
254     2233    22.33
255     2239    22.39
It's even easier if 'adc' is a word variable and you use READADC10 ... ' afr = adc ** 30815 + adc + 735'
neiltechspec
Thanks hippy, look interesting.
I'll try it on the H/W tomorrow.
for info, entire code is here.
#rem
7 Seg Com Anode display direct drive AFR Meter
0-5v, 7.3 - 22.4 AFR. (AFR = Volts *15.04/5+7.35)
Display limited from min 10.0 to max 19.9
Using PICAXE20M2, V2, Jun 2022
Connections:
tenths
c.0 ..... 330R to Segment  a
c.1 ..... 330R to Segment  b
c.2 ..... 330R to Segment  c
c.3 ..... 330R to Segment  d
c.4 ..... 330R to Segment  e
c.5 ..... 330R to Segment  f
c.7 ..... 330R to Segment  g
units
b.1 ..... 330R to Segment  a
b.2 ..... 330R to Segment  b
b.3 ..... 330R to Segment  c
b.4 ..... 330R to Segment  d
b.5 ..... 330R to Segment  e
b.6 ..... 330R to Segment  f
b.7 ..... 330R to Segment  g
470R to -ve for DP
470R's from A.0 to Tens segments B & C
#endrem
#picaxe 20m2
#no_data
symbol sens  = b.0    'has 47uF across it & 10k in series with I/P to damp readings
symbol adc   = w1
symbol afr   = w2
symbol volts = w3
symbol delay = 100
init:
        pullup 16384
        high A.0
        dirsB = %11111110
        dirsC = %10111111
        pinsB = %11111110 'blank tenths
        pinsC = %10111111 'blank units
         gosub test
        setfreq m16
afratio:    '7.35 to 22.39 afr, limited to min 10.0, max 19.9
    readadc10 sens,adc
    afr = adc ** 30815 + adc + 735 min 1000 max 1999
    select case b13
     case 48 let pinsB = %10000000    '0
     case 49 let pinsB = %11110010    '1
     case 50 let pinsB = %01001000    '2
     case 51 let pinsB = %01100000    '3
     case 52 let pinsB = %00110010    '4
     case 53 let pinsB = %00100100    '5
     case 54 let pinsB = %00000110    '6
     case 55 let pinsB = %11110000    '7
     case 56 let pinsB = %00000000    '8
     case 57 let pinsB = %00110000    '9
    endselect
    select case b12
     case 48 let pinsC = %10000000    '0
     case 49 let pinsC = %10111001    '1
     case 50 let pinsC = %00100100    '2
     case 51 let pinsC = %00110000    '3
     case 52 let pinsC = %00011001    '4
     case 53 let pinsC = %00010010    '5
     case 54 let pinsC = %00000011    '6
     case 55 let pinsC = %10111000    '7
     case 56 let pinsC = %00000000    '8
     case 57 let pinsC = %00011000    '9
    endselect
    if b11 = 48 then high A.0
     else low A.0
    pause 400
test:
        pinsB = %10000000    'display "0"
        pinsC = %10000000    'display "0"
        pause delay
        pinsB = %11110010    'display "1"
        pinsC = %10111001    'display "1"
        pause delay
        pinsB = %01001000    'display "2"
        pinsC = %00100100    'display "2"
        pause delay
        pinsB = %01100000    'display "3"
        pinsC = %00110000    'display "3"
        pause delay
        pinsB = %00110010    'display "4"
        pinsC = %00011001    'display "4"
        pause delay
        pinsB = %00100100    'display "5"
        pinsC = %00010010    'display "5"
        pause delay
        pinsB = %00000110    'display "6"
        pinsC = %00000011    'display "6"
        pause delay
        pinsB = %11110000    'display "7"
        pinsC = %10111000    'display "7"
        pause delay
        pinsB = %00000000    'display "8"
        pinsC = %00000000    'display "8"
        pause delay
        pinsB = %00110000    'display "9"
        pinsC = %00011000    'display "9"
        pause delay
        low A.0
        pause delay
