RacingtoMars
Hi all,
I'm currently tinkering (between studying/decorating/childcare) with an MSF receiver module from PV Electronics, and I've been reading through all the previous postings on the forum (thanks!).
First, I feel I must declare that I work for Maplin and that this isn't a product plug!!
I bought an Acctim radio controlled analogue clock which is currently on offer for a tenner, in order to replace the module in a more decorative clock that we have. Now, the Acctim clock uses a Sheng Bang 1688 module which doesn't have a threaded collar like every other clock in our house — it's held in place by two screws on the back. But, after removing it anyway, I discovered a recess in the case, and some tiny little solder pads on the PCB. There are two pads connected directly to the battery terminals and a third which I measured as having a 60kHz signal at approx 6.8 mV peak-to-peak.
The signal (shown on the mini digital o'scope I used) appeared to offset positively slightly, in time with the LED blinking on my MSF module.
Just thought I'd share my findings in case someone finds this useful!
