I've been looking around for a good, cheap beginners GPS module for awhile. Then, about two weeks ago, I saw the PA6B on the 4D Systems website. It is quite cheap ($30 US) and it seems fairly easy to work with. The only problem I saw with it is that it's connectors are quite small to keep it's size down, making it hard to connect to a breadboard. However, for an extra $10 US you can buy it soldered onto a breakout board. Problem solved.
My question is, does anyone else have experience with this particular GPS module? Or does anyone see any potential problems that a GPS beginner might run into? I don't need anything amazing, 1Hz update rate is all I need and it also supports USB. It consumes 37mA while tracking which, while quite a bit, is fairly standard for GPS. It also has "Jammer detection and reduction" which, if I ever build a vehicle tracker (I would use it legally of course), would be nice.
