Those data pins are already joined on the ZW3102. Just in case another offering is used perhaps indeed the PCB should not have them connected. Stan.
OK.The data pin used (digital data) is the second pin in from the end, the 3rd pin in is the analog data pin.
Original post was 0.4mm, but it is now 1mm to satify student requirements.What is the spacing used between pads and ground plane, as i like at least 0.6mm because it saves the hassle of bridges in home development of boards.
Its not that i can not go finer but why risk the chances of a bridge occuring in a area that dont really matters two hoots i think.
Completely open to any suggestions.G: 1mm suits both novices & weary eyed seniors well I'd say. If you're tweaking anything more maybe say 433.92 MHz (rather than 433) as some outlets refer to it as 434 MHz. Given my musings above, before going too far it may well be worth testing (or making provision for) both the RXD1 & RXB1 in the sniffer circuit. Stan
I will do 2 posts as we can only post 2 photos at a time.
Jaycar's new ZW-3102 433 MHz data receiver (based around Princeton Tech's PT4302 RF IC ), is thankfully pin for pin compatible to their traditional ASK module. Aside from their intended data duties, band "sniffing " persuasion gives piezo based audio that also seems superior in both in volume and clarity to their classic Keymark offering.
The module especially scores over Dorji's cheaper 433 MHz receiver for it's ability to work down to 2.4V. Such a flexible supply nicely suits powering by a single Li coin cell, single LiFePO4 or 2 x AA etc.
It's shown itself significantly more sensitive than before. Semi line of sight signals (through light vegetation and wooden buildings) from a 25mW tone sending Dorji transmitter were still audible when some 100m away.
Data sheet sleuthing pleasingly reveals a signal strength point at PT4302 pin 14 ,which conveniently runs to a good solder point at SMD capacitor C5. A wire can be run from this to a duplicated module data pin that's freshly isolated (by PCB track cutting).
The voltage swing here suits useful RSSI work, as it varies between 0.9V with just band noise and ~1.4V with a strong nearby signal. DMM monitoring here could allow keen insights into transmitter,propagation path and antenna performance. A simple LED (perhaps wired via a boosting Darlington Pair) however could be enough for proximity and visual checking on such suspect transmitters as 433 MHz wireless doorbells.
As these ZW3102 modules are available off the shelf at any Jaycar they may be worthwhile for general 433 MHz use, even though they're more costly than other offerings.
