Hi, I have just started using picaxe and im trying to get my head around a few things.. currently im using a 40X2 to interface a wavecom GSM modem to a set of inputs and outputs as part of a system monitor. all the code seems to run well and I will post the code when i have cleaned it up . as an added extra i want to interface an LCD display to show status messages, I have copied the code from the instruction manual however it errors due to the use of pins = .
From what i can understand that command is used to set specific pins as outputs.
Can anyone point me in the right direction on how to rewrite this to work with a 40X2 ?
Regards
Duncan
Regards
Duncan
