40X1 dirsb syntax
john2051
Hi, I am using a picaxe 40x1 on an axe091 board. Trying to set all the pins with "let dirsb=255" results in a syntax error and yet dirsc works.
I have looked through the manuals, and I can't seem to find out why. BTW if I use a 40x2 it works!
Any help, or explanation or equivalent would be appreciated.
thank you
Please see part 1 of the manual for the 40X1 pinout diagram. You will see portB are outputs only on this older part. Hence no dirsB command is required or supported.
papaof2
I'll guess you did NOT tell the editor which PICAXE you were using. If you had, the error message from the Syntax Check would have been:
let dirsb=255
Error: Unknown symbol - dirsb
"Unknown symbol" because that command does not exist for the 40X1.
john2051
Thanks to both, tired eyes and trying to work things out late in the evening and I missed these.
Much appreciated, thank you
