Picaxe Ceramic Resonators Surface Mount or Through Hole range 4MHz, 8MHz, 10MHz, 16MHz have internal caps.
In online datasheets they can vary from 5 to 47pF.
What are those Picaxe resonator caps values?
We assume you are asking the question so that you can use a 2 pin type resonator. However that is working the wrong way around - you should look at the 2 pin type datasheet and use the capacitors they recommend rather than just copy what is inside a particular 3 pin type.
The load capacity marking only really applies to 2 pin devices - as we said earlier you look at the marking and use the capacitor stated.
If it is a 3 pin device the capacitor is internal and will be correctly matched already, so it doesn't matter what it is - and that section of the datasheet doesn't apply to 3 pin devices. The devices we sell are 30 but any 3 pin device will work.
Ceramic resonators are not crystals.
Whereas a crystal requires external loading capacitors, a resonator has intrinsic distributed capacitance as part of the component itself. You don't have worry about the actual value, the manufacturer has already done that to ensure optimum oscillation accuracy.
